I finally built my control box with the vacuum switch discussed here:
Thanks to @ClayJar for the write-up on the three way switch. It’s exactly as you described. I added a second switch to the right of the vacuum switch to override & turn off the vacuum when powered by IoT, for jobs that don’t need the dust boot. I also have my kill and pause switches in there, and the IoT off to the side with a removable access panel.
Now I can start a job & walk away if I want, and don’t have to come back to shut off the vacuum. Plus I can hear the vacuum shut off from another room so I know the job is done.
Those labels are temporary - I’ll do something nicer & neater soon, because OCD.
