i just upgraded to carbide create pro. i am having issues with tool change prompts while running a program. The cnc will stop as if its doing something but will not prompt the next tool change. It just sits there as if i need to do something but no matter how long I wait, it doesnt do anything.
Do you have a BitSetter?
Is it configured and enabled?
Which post-processor are you using under Edit | Select Post-processor? It should be “Carbide 3D Shapeoko”
I have the v1 and the bit setter enabled. I do need to get back to my computer and check post processor
