hey all well I’m on the 14 day trial for cc pro 1 sorting most designed save the Toolpaths simulated all good so far using UGS as the sender !
cant find a video anywhere that shows the procedure when it stops you change tool rezero z then things go hey wire . help
pat
Do you have a BitSetter? If not, you need to save your project with one tool per file, and then run them one after another, changing tools manually between files.
If you do have a BitSetter, you would need to find out how to configure UGS to use a tool probe.
If you’re using UGS, I think you’d probably be better saving each tool as a separate G-code file.
Thanks for your help! That worked do you do the same with a vecarve that has a clean out pick ? Split the tool path and send them separately? Pat
Yes, that is why the current implementation of V carving creates two separate toolpaths.
