Hello all,
I finally have cncjs setup and working great except for one small thing. For reference I have a Shapeoko 4 Pro XXL which has the BitSetter
I have been using @neilferreri tool change macros referenced here:
My current process is the following:
Create tool paths on fusion and export them into 2 NC Files. First uses a 0.25 flat bit and the second uses a 0.25 ball nose bit.
Set stock 0
Run the Inital Tool Macro
Start Job
Stop router and run New Tool Macro
Change bit while paused and then resume probe
After running the second probe the tool has not updated the stock Z to the new offset. So far it has always been higher but not constantly higher. I have been verifying on part of the stock where I originally set 0.
