Tool path for Blum hinges?
I’m looking for a program to start with for Blum cabinet hinges with a 1-9/16 overlay. Basically just needs to cut the pocket and the pilot holes. I’m sure I can build from scratch but I figured SOMEBODY would have a carbide create file for it, and maybe be able to tell me how far from the edge I need to center the pocket?
Particular hinge model is the 39C355B.25
Thanks in advance for any help!
compact39c_install (1).pdf (1.9 MB)
Thanks, I saw that on their site, I’m just wondering if anybody has a file built to cut them already
It’s pretty simple to do — open the PDF, make a screengrab:
Import that into Carbide Create:
Draw a copy of the largest feature at the correct size:
and adjust the embedded pixel image until things line up:
and check using other dimensions:
Then draw in the other elements:
and then assign toolpaths:
Adjust as need be to match the hardware and so forth:
Blum_hinge.c2d (152 KB)
I don’t. I use a drill and forstner. I think this would be a pretty quick design.
This is awesome, thanks all!
