Tool path showing wrong bit in V8
I am trying to make a logo for a friend’s business. I designed the file in V815 and set the V-Carve toolpath named Pend to use a 60-degree V-bit. When I hover over the toolpath it states to use a 1/8 bit.
When I open the file in CC V778, it correctly lists a 60-degree V-bit when I hover over the toolpath.
What is wrong?
Pendorheim Draft 3.c2d (304 KB)
If a V carving toolpath is set up w/o the Pocket Clearing option, the default for that will show in the hover prompt — I just set it up to use the correct V tool for pocket clearing if not using that option.
That reply took almost 3 minutes to get to me. Amazing!!
