Hi All,
I have a pretty simple logo with one pocket, a copy of that toolpath with smaller bit (rest machining), and appears that the toolpath executes two times, greatly increasing the processing time. For instance, I start with 1/4" cutter to remove most of the waste. That part of the program runs two times, with the bit going around over the already cut areas. Then I get the bit change to 1/8" and that path runs one time. What could be causing the 1/4" tool path to be going two times?
It could be a rounding error with the depth per pass and the max depth. Do you have them set the same? Set the depth per pass deeper than the max depth.
