I have a toolpath that goes off the edge of my stock in two places, once on the left, once on the right. One place it cuts fine (right side), the other place it essentially skips this section of the path (left side). I suspect that maybe it’s because the center of the cutter is going off the stock? I’m sure there’s a way to manually work around this but is there some option I’m missing that would allow the cutter off the stock?
I never use the stock size as my bounds for the actual stock. I make the stock size larger in the settings and then make a rectangle that is the actual size of my stock to work within. That way if I need to carve outside the stock size there is no issue.
Most of my work is zeroed on the center but it can still work with a corner just don’t have the tool path going off an edge that is right along the edge of the machine stick. So if you use the bottom left as zero you can go off the edge on the top or right of the false material.
The tiling option limits cutting to w/in a tile, including at the sides.
You will need to increase the width of the stock in Carbide Create and adjust your stock placement (if it’s actually 12 inches wide) to account for the shift.
