I made a pretty simple vacuum table, 4ea 21" square grids with 1x1 spacing. The toolpath was incredibly inefficient. There was no pattern at all, it would cut one line on the top left grid then go and cut two on the bottom right and then who knows where is next. The question I have is, can you modify the toolpath that create pushes to motion?
It would be necessary to do this in Carbide Create — select individual elements and assign discrete toolpaths, creating the desired ordering.
