shaft diameter is given on the shop page â itâs the diameter of the shaft which will go into the collet, 0.125 for a #111 â shank is another word for this
flute diameter is the diameter at the cutting flutes, 0.0625 for a #111
flute length is how deeply the endmill will be able to cut, so also loc, length of cut
not sure what cd is in this context â could you provide a reference or screen grab?
Is the truncation of 0.0625 -> 0.062 in the cutter information reflected in the value stored in CC when generating toolpaths? Or is it just the display mask?
Once you care about that much, one also needs to measure the actual cutter⊠thereâs likely a bunch of variance between each cutter at least this much
Different versions of Carbide Create round off differently. I believe new ones allow greater precision, and one can always edit the underlying file.
If youâre more comfortable with metric, entering in that system gets one either 1.587 or 1.588mm which are just 0.0005mm off which I hope is reasonable enough.
Why is oal (over all length) missing from this information? I am new, and finding this information is difficult. It would be helpful to be able to load the tools from the select tool page, but only one is listed - and this tool changes each time I open Meshacam.
I edited the script per Eddie Garmons advice, but no effect on Meshcam 6.
Does anyone have a cheat sheet of the following with all the information required in the tool definer?
Carbide Create has reduced the characteristics shown/entered to the bare minimum since it now uses curated feeds and speeds which are entered rather than calculated, so no further numbers are needed (they can still be entered directly into the files, but that is not necessary for normal usage).
