I am designing a plate in CC.
On the bottom I have an inner pocket which runs as expected.
I have also created an outer pocket leaving a small ridge on the bottom of the plate on which it sets.
Anyway, there is one line of toolpath where the line is broken and causes it to rapid oddly skipping back and forth wasting time.
Picture provided…
Interesting, it may be a math/rounding error bug for that specific circle diameter and tool.
Can you upload the c2d file here for a check ?
If my hunch is correct, you might be able to get rid of it by ever so slightly increasing the outer diameter (just changing the last decimal may be enough). Or alternatively decreasing the diameter of the inner circle by a hair.
Ok, it’s definitely a bug (or limitation, at least). I was able to reproduce it using any two concentric circles when the difference in radius is exactly an integer number of times the endmill diameter. As in this example with a 2" circle, a 4" circle, and using a 1/4" endmill
