I haven’t found a torque curve published anywhere for the Nomad’s spindle, and was wondering if we could get something from @Jorge or @robgrz on this, as that’d help a lot for setting optimal feeds & speeds. Thanks!
I upgraded my Nomad Pro to the 42BLF03 78 Watt and ran across this data sheet.
http://www.wantmotor.com/wap/product/Brushless_DC_motor/index.aspx?id=84
Edit: Forgot to mention it is generally assumed that the Nomad uses the 42BLF02, but I could be wrong. Either way, the 78 Watter works with stock electronics.
