I have the reserved connector on my board, does that mean i do not need the red green white wire harness?
Also if i connect the probe to the reserved spot i cant disconnect it after probing, does the probe always stay connected to PCB, even during cutting
This might help you:
I connected mine to an aircraft plug in the electronics cover. Plug it in to probe, un plug and put away afterwards.
It’s the one on the front of the case. The one with the dust cap attached.
