I have a green light on the probe, when i touch the clip to the probe block it does not change to red.
Build: 4.0.414 of CM
i attached the clip to the belt tightening screw
Touch with the probe a unpainted part of the Y axis to check if it works.
If it works, you just have the problem that the clip has no electrical contact at the screw.
In this case check that a unpainted part has electrical contact to the clip.
