Tracing and image to make larger
Id like a 1/8 outline of this symbol {Black} So essentially trace the image 1/8 larger perimeter (White).
Its to make two layers. One slightly larger with the smaller on top. Each time i try to change the size they match up more like a shadow effect. The black and white [picture transfers better, but im looking to make the red and black sign.
How do i trace or blow up an object
ff
You would need to fill in the design to get a single outline — what you are describing as a shadow effect is the inside and outside of the line both being traced — but you can just delete whichever you don’t want and then offset the remaining geometry the desired distance.
this is my enlarging result.
Don’t enlarge, use Offset:
Here’s a .c2d file which has this done, but w/o converting to a polyline:
ff.c2d (88 KB)
