Translation for carbide create 7
hello, i Don’t find how to change the language in carbide create 7. can you help me. and a manual for the v7 in pdf.
Thank you
At this time, Carbide Create (and Motion) are English-only.
While not a PDF, I did work up:
and if you have a Pro license:
which should be up-to-date with the current version — if not, let me know and we will look into it with you.
but there is folders called translation and translations and in the second one there’s many files qt_xx.qm
xx are the letters of the country, so what is it for?
thanks for your help , i bougth it for a week and i don’t try every thinks. i saw some tutorials on youtube.
The translation folders and contents are placeholders for the cross-platform framework (QT) which we used.
I will note that one resource which we have:
was created by a French-speaker, @Julien as part of improving his fluency with English.
Back when the wiki was on-line there were efforts at other languages for the Glossary:
French: https://web.archive.org/web/20211130160545/https://wiki.shapeoko.com/index.php/Glossary_French
Italian: https://web.archive.org/web/20211130160545/https://wiki.shapeoko.com/index.php/Glossary_Italian
German (incompleat): https://web.archive.org/web/20211130160545/https://wiki.shapeoko.com/index.php/Glossary_German
and the English language original had some notes on Spanish resources: Glossary - ShapeOko
That said, the English version is more up-to-date:
ok i see.
thank you for your help and your links. it will be usefull for me.
