Can’t move images in design when I In large them.
Please post the file.
The only reason things shouldn’t move are:
- initial selection — you have to click on them and drag a second time to move them
- on a locked layer — but then they can’t be selected
- EDIT: as @gdon_2003 noted, not being in the Design view
Depending on your experience you cannot move objects when not in Design mode. If you are in the ToolPath mode objects can be highlighted but not moved until you go to Design mode. That may be your problem.
