I am new to the Carbide world and very happy to be a part of it.
I am having trouble saving my projects from Carbide create. When I click “Save GCode” it saves the file as a Text Edit Document. I’m not sure if I changed a setting at some point, somehow but does anyone have any advice on how I can change this back to normal??
It’s harmless (and kind of convenient) to open the .nc files in a text editor — the only concern is that they have a file extension which will allow opening them in Carbide Motion — does that work?
As I was reading your post I think you might have mixed up saving your project and saving gcode. They are two separate things. Your Carbide Create project is a separate operation to enable you to reopen your project later in Carbide Create. Saving gcode is saving tool paths that Carbide Motion can use to cut out your project.
The Carbide Create files are saved in this format: project.c2d
The gcode files are created in this format: toolpath.nc
If I misunderstood the problem sorry but Will Adams is right about the bug for Macs. The files for tool paths are still good you just have to edit it and add the .nc extension. All gcode files are text documents.
CC does not add an extension automatically. There are other machines that use other extensions for G-Code even though it has the same coding to run it.
You have to add the extension needed for your machine. Using CM .NC is needed.
The Text files you already have just rename them with a .nc at the end and they should run fine.
To make it easier on yourself you may want to keep all G-Code files together maybe separating them into sub-directories by project, material, size or something more to remind you where it is.
I usually save my file so I can identify them better as well.
Like - Leaves 90V - 102 bit contour.nc
Hope this helps.
I have CC-526 and it does not add extension automatically?
I have to add manually.
I think I may know why.
There is a drop down box and it has several extensions listed on the line.
I may be able to click on the dropdown box and select one extension to have it come up with .nc from now on?
NOPE - “G-Code files (*.nc *txt *tap)” is how it reads. Even though there is a drop down box it only has the one option and will not save unless I type it in?
