I am using Fusion 360 to draw and create G-code I use metric so I don’t run into the translation issue with it, but I still have my code either just don’t do anything after you load the end mill, or after a bit without moving it gives me a limit switch hit. I’m not sure what to do. I am thinking about using different g-code sender maybe one that I can see what is going on. I know it’s been asked be for but what do most of you use? or is there something I need to change in what I am doing now?
here is the begging part of my code that did not start at after the stop for the end mill. the code is really simple just a 4 circles with a holes in the middle of each
(wire backing )
(cut out )
(T1 D=6.35 CR=0 - ZMIN=-7.85 - flat end mill)
G90
G17
G21
G28 G91 Z0
G90
(2D Adaptive2)
M9
T1 M6
S8000 M3
G54
M7
G0 X-286.138 Y-83.783
Z15
Z5
Z3.185
G1 Z2.55 F1219.2
G3 X-284.806 Y-89.667 Z2.219 I0.666 J-2.942
X-286.138 Y-83.783 Z1.888 I-0.666 J2.942
X-284.806 Y-89.667 Z1.557 I0.666 J-2.942
X-286.138 Y-83.783 Z1.226 I-0.666 J2.942
X-284.806 Y-89.667 Z0.895 I0.666 J-2.942
X-286.138 Y-83.783 Z0.565 I-0.666 J2.942
X-284.806 Y-89.667 Z0.234 I0.666 J-2.942
X-286.138 Y-83.783 Z-0.097 I-0.666 J2.942
X-286.661 Y-89.497 Z-0.362 I0.666 J-2.942
X-282.455 Y-86.728 Z-0.57 I1.189 J2.772
X-288.488 Y-86.721 Z-0.901 I-3.016 J0.004
X-287.559 Y-88.902 Z-0.986 I3.016 J-0.004
X-282.649 Y-87.788 Z-1.194 I2.087 J2.178
X-288.294 Y-85.662 Z-1.525 I-2.823 J1.063
X-288.191 Y-88.031 Z-1.61 I2.823 J-1.063
X-282.753 Y-85.419 Z-1.941 I2.719 J1.306
X-288.191 Y-88.031 Z-2.272 I-2.719 J-1.306
X-282.753 Y-85.419 Z-2.603 I2.719 J1.306
X-288.191 Y-88.031 Z-2.934 I-2.719 J-1.306
X-282.753 Y-85.419 Z-3.265 I2.719 J1.306
X-288.191 Y-88.031 Z-3.595 I-2.719 J-1.306
X-282.753 Y-85.419 Z-3.926 I2.719 J1.306
X-288.191 Y-88.031 Z-4.257 I-2.719 J-1.306
X-282.753 Y-85.419 Z-4.588 I2.719 J1.306
X-288.191 Y-88.031 Z-4.919 I-2.719 J-1.306
X-282.753 Y-85.419 Z-5.25 I2.719 J1.306
X-288.191 Y-88.031 Z-5.581 I-2.719 J-1.306
X-282.753 Y-85.419 Z-5.912 I2.719 J1.306
X-288.191 Y-88.031 Z-6.243 I-2.719 J-1.306
X-282.753 Y-85.419 Z-6.574 I2.719 J1.306
X-288.191 Y-88.031 Z-6.904 I-2.719 J-1.306
X-282.753 Y-85.419 Z-7.235 I2.719 J1.306
X-288.191 Y-88.031 Z-7.566 I-2.719 J-1.306
X-282.455 Y-86.725 Z-7.85 I2.719 J1.306
X-288.488 I-3.016 J0
X-285.472 Y-89.741 I3.016 J0
X-282.563 Y-87.522 I0 J3.016
X-282.455 Y-86.725 I-2.909 J0.797
G1 X-282.451 Y-86.479
X-282.273 Y-85.514
X-282.248 Y-85.197
X-282.291 Y-84.882
X-282.4 Y-84.583
X-282.57 Y-84.315
X-282.624 Y-84.247
X-282.795 Y-84.041
X-282.813 Y-84.024
X-283.09 Y-83.801
X-283.37 Y-83.578
X-283.464 Y-83.51
X-283.687 Y-83.399
X-284.133 Y-83.184
X-284.201 Y-83.154
X-284.269 Y-83.132
X-284.803 Y-83.01
X-285.026 Y-82.962
X-285.249 Y-82.954
X-285.695
X-285.918 Y-82.962
X-286.141 Y-83.01
X-286.587 Y-83.112
X-286.673 Y-83.132
X-286.742 Y-83.154
X-286.81 Y-83.184
X-287.256 Y-83.399
X-287.479 Y-83.51
X-287.573 Y-83.578
X-287.925 Y-83.859
X-288.13 Y-84.024
X-288.148 Y-84.041
X-288.319 Y-84.247
X-288.595 Y-84.593
X-288.67 Y-84.693
X-288.786 Y-84.916
X-289 Y-85.362
X-289.041 Y-85.451
X-289.079 Y-85.585
X-289.181 Y-86.031
X-289.231 Y-86.254
X-289.242 Y-86.477
Y-86.923
X-289.238 Y-87.146
X-289.192 Y-87.369
X-289.09 Y-87.815
X-289.041 Y-87.999
X-289.024 Y-88.038
X-288.81 Y-88.484
X-288.701 Y-88.707
X-288.595 Y-88.857
X-288.358 Y-89.153
X-288.178 Y-89.376
X-288.148 Y-89.408
X-287.916 Y-89.599
X-287.636 Y-89.822
X-287.479 Y-89.94
X-287.256 Y-90.051
X-286.805 Y-90.268
X-286.696 Y-90.311
X-286.587 Y-90.338
X-286.141 Y-90.44
X-285.918 Y-90.489
X-285.897 Y-90.491
X-285.695 Y-90.496
X-285.249
X-285.046 Y-90.491
X-285.026 Y-90.488
X-284.803 Y-90.44
X-284.356 Y-90.338
X-284.247 Y-90.311
X-284.133 Y-90.266
X-283.675 Y-90.045
X-283.464 Y-89.94
X-283.307 Y-89.822
X-283.018 Y-89.592
X-282.795 Y-89.409
X-282.764 Y-89.376
X-282.407 Y-88.93
X-282.29 Y-88.782
X-282.242 Y-88.707
X-282.026 Y-88.261
X-281.919 Y-88.038
X-281.903 Y-88
X-281.853 Y-87.815
X-281.751 Y-87.369
X-281.705 Y-87.146
X-281.701 Y-86.923
Y-86.366
X-281.712 Y-86.254
X-281.813 Y-85.808
X-281.864 Y-85.585
X-281.903 Y-85.449
X-281.942 Y-85.362
X-282.157 Y-84.916
X-282.272 Y-84.693
X-282.349 Y-84.592
X-282.57 Y-84.315
X-282.613 Y-84.28 Z-7.844
X-282.654 Y-84.247 Z-7.825
X-282.69 Y-84.217 Z-7.795
X-282.72 Y-84.192 Z-7.756
X-282.743 Y-84.173 Z-7.709
X-282.76 Y-84.164 Z-7.656
X-282.765 Y-84.161 Z-7.601
G0 Z5
X-275.434 Y-269.942
Z3.185
G1 Z2.55 F1219.2
G3 X-277.211 Y-274.652 Z2.342 I0.666 J-2.942
X-272.325 Y-271.115 Z2.011 I2.443 J1.769
X-277.211 Y-274.652 Z1.68 I-2.443 J-1.769
X-272.891 Y-275.245 Z1.51 I2.443 J1.769
X-273.335 Y-270.23 Z1.302 I-1.877 J2.361
X-276.202 Y-275.537 Z0.971 I-1.433 J-2.654
X-273.84 Y-275.753 Z0.886 I1.433 J2.654
X-272.494 Y-270.902 Z0.678 I-0.928 J2.87
X-277.484 Y-271.571 Z0.47 I-2.274 J-1.981
X-272.052 Y-274.196 Z0.139 I2.716 J-1.313
X-276.85 Y-270.701 Z-0.154 I-2.716 J1.312
X-275.957 Y-275.655 Z-0.362 I2.082 J-2.183
X-271.752 Y-272.887 Z-0.57 I1.189 J2.772
X-277.784 Y-272.88 Z-0.901 I-3.016 J0.004
X-276.855 Y-275.061 Z-0.986 I3.016 J-0.004
X-272.681 Y-270.706 Z-1.317 I2.087 J2.178
X-274.9 Y-269.87 Z-1.402 I-2.087 J-2.178
X-277.487 Y-274.189 Z-1.61 I0.132 J-3.013
X-272.049 Y-271.578 Z-1.941 I2.719 J1.306
X-273.833 Y-270.016 Z-2.026 I-2.719 J-1.306
X-275.703 Y-275.751 Z-2.357 I-0.935 J-2.868
X-273.341 Y-275.541 Z-2.442 I0.935 J2.868
X-272.886 Y-270.527 Z-2.65 I-1.427 J2.657
X-277.675 Y-272.079 Z-2.858 I-1.883 J-2.357
X-271.861 Y-273.688 Z-3.189 I2.907 J-0.805
X-277.675 Y-272.079 Z-3.52 I-2.907 J0.805
X-271.861 Y-273.688 Z-3.851 I2.907 J-0.805
X-276.428 Y-270.365 Z-4.106 I-2.907 J0.805
X-276.431 Y-275.4 Z-4.314 I1.66 J-2.518
X-273.105 Y-270.367 Z-4.645 I1.663 J2.516
X-276.431 Y-275.4 Z-4.976 I-1.663 J-2.516
X-273.105 Y-270.367 Z-5.307 I1.663 J2.516
X-274.362 Y-269.895 Z-5.354 I-1.663 J-2.516
X-277.676 Y-273.685 Z-5.562 I-0.406 J-2.989
X-272.888 Y-275.242 Z-5.77 I2.908 J0.801
X-276.648 Y-270.525 Z-6.101 I-1.88 J2.359
X-273.837 Y-275.752 Z-6.394 I1.88 J-2.359
X-272.496 Y-270.899 Z-6.602 I-0.931 J2.869
X-277.04 Y-274.867 Z-6.933 I-2.272 J-1.984
X-274.904 Y-275.897 Z-7.018 I2.272 J1.984
X-274.632 Y-269.87 Z-7.349 I0.136 J3.013
X-276.852 Y-270.703 Z-7.434 I-0.136 J-3.013
X-275.954 Y-275.657 Z-7.642 I2.084 J-2.18
X-271.752 Y-272.883 Z-7.85 I1.186 J2.773
X-274.768 Y-269.867 I-3.016 J0
X-277.784 Y-272.883 I0 J-3.016
X-274.768 Y-275.9 I3.016 J0
X-271.859 Y-273.681 I0 J3.016
X-271.752 Y-272.883 I-2.909 J0.797
G1 X-271.748 Y-272.638
X-271.57 Y-271.673
X-271.543 Y-271.368
X-271.579 Y-271.065
X-271.677 Y-270.775
X-271.832 Y-270.511
X-271.956 Y-270.343
X-272.007 Y-270.288
X-272.068 Y-270.232
X-272.587 Y-269.786
X-272.672 Y-269.727
X-272.757 Y-269.681
X-273.203 Y-269.445
X-273.426 Y-269.34
X-273.873 Y-269.219
X-274.096 Y-269.159
X-274.207 Y-269.135
X-274.319 Y-269.126
X-274.988 Y-269.101
X-275.067 Y-269.105
X-275.146 Y-269.117
X-275.657 Y-269.213
X-275.88 Y-269.26
X-276.077 Y-269.34
X-276.588 Y-269.563
X-276.68 Y-269.61
X-276.772 Y-269.676
X-277.224 Y-270.009
X-277.333 Y-270.092
X-277.442 Y-270.209
X-277.845 Y-270.678
X-277.888 Y-270.731
X-277.985 Y-270.901
X-278.221 Y-271.347
X-278.279 Y-271.458
X-278.32 Y-271.57
X-278.499 Y-272.239
X-278.52 Y-272.35
X-278.525 Y-272.462
X-278.542 Y-272.908
X-278.55 Y-273.131
X-278.517 Y-273.354
X-278.432 Y-273.8
X-278.383 Y-274.023
X-278.334 Y-274.14
X-278.093 Y-274.692
X-278.035 Y-274.803
X-277.955 Y-274.915
X-277.626 Y-275.361
X-277.549 Y-275.459
X-277.442 Y-275.558
X-276.995 Y-275.941
X-276.88 Y-276.03
X-276.772 Y-276.089
X-276.215 Y-276.384
X-276.103 Y-276.429
X-275.434 Y-276.609
X-275.322 Y-276.633
X-275.211 Y-276.64
X-274.542 Y-276.665
X-274.486 Y-276.663
X-274.43 Y-276.656
X-273.873 Y-276.551
X-273.65 Y-276.504
X-273.573 Y-276.476
X-272.98 Y-276.217
X-272.869 Y-276.163
X-272.757 Y-276.085
X-272.311 Y-275.756
X-272.214 Y-275.683
X-272.118 Y-275.584
X-271.734 Y-275.138
X-271.642 Y-275.027
X-271.577 Y-274.915
X-271.341 Y-274.469
X-271.231 Y-274.246
X-271.196 Y-274.121
