WillAdams
(William Adams (Carbide 3D))
2
The suggestion to swap the X and Z was wrong — swap things back.
For the Z going down, this can be caused by multiple things:
- incorrect Grbl and Machine configuration, see:
- Z-axis switch stuck on — none of the switches should be stuck on
- machine up against an edge — move towards the center before powering up
If you continue to have difficulties let us know what your machine does when you attempt to initialize at support@carbide3d.com
