Trying to create a logo for engraving a branding iron
Alan,
Glad that is what you were looking for. My process was:
  1. Use Google to find the highest resolution image of the logo you want. You can have Google filter images by clicking on the “Tools” button in the image search window:
Then you can select “Size” ==> “Large”:
That will get you the highest resolution images and filter out the lower resolution images.
  1. Import it into Inkscape, and for this specific image, it made sense to use the “Brightness Cutoff” option in the “Path” ==> “Trace Bitmap” command.
  2. I just guessed at the font for the “Whangamata” and Century Gothic seemed close enough, so I went with it.
  3. The last thing (that I forget to do as well) is to convert the text to a vector by selecting the text, then select “Path” ==> “Object to Path”. It is now no longer editable text. It is set of combined closed paths. To separate them into individual letters, you must use “Path”==>“Break Apart” instead of the “Object”==>“Ungroup” command. Then re-select individual parts of a letter like the inside of the R, P, O and Q letters, and then group them together so they are easier to move each letter if you want. Usually, because I want to be able to change the text later, I will make a copy of the text and then convert one copy to a path, and keep the other text.
The cool thing about that is, the g-code generating program I use (Makercam, mostly, but Vectric V-Carve as well) doesn’t see the text, so it is “invisible” when I am converting the file to g-code.
I love Inkscape because of the many commands you can use to align, group, ungroup, snap, center, copy, distribute evenly. . . .
Anyway, glad I could help out, and don’t forget to show us your completed project.
