I want to cut an Album for a barber friend of mine, and I set an offset of it it has a comb in it of course and it seems it just don’t look right in the picture or preview…I should probably do an inside and outside offset with picking the outside and inside correct? and ignore the original…does that sound right?
Yes, especially if you just want to cut out part and keep it, while discarding the balance.
Problem is, how do you get those small details? what size bit? I tried an offset with the Comb in it and still can’t get the teeth right…
