in 1 pass. Drew and easy zig zap in Create just with 2 rows to see how it would behave in an “air pass”. Selected .030" dept per/pass and .030" max depth. Starts and enter just as I drew, completes both rows, goes back to original start position and re-cuts the file again. Is there a max/min setting I can enter or another command I’ve overlooked to compete the tool path in 1 pass?
Tnx
ps. I’m drawing this as a zig zag and selecting a Contour no offset, not a Pocket feature.
You did not say what kind of machine you have. I have an SO3 with a supplemental spoilboard. I created a document that talks about optimizing a supplemental spoilboard and how to surface that spoilboard. Here is my document. If you have the hybrid table much of it still applies.
I use a Whiteside 6210 1" carbide fly bit to surface. My DOC is 0.01". I make a single pass with pencil marks all over my spoilboard. If there are any pencil marks left I rezero in that spot and run the job again. I want to take off as little of my spoilboard as possible but still get it flat. If you have cut very deeply into your spoilboard you may just have to live with it and not flatten all the way to make all marks disappear.
Here is my custom tool database for the Whiteside 6210 bit and a clone that is identical.
number
vendor
model
URL
name
type
diameter
cornerradius
flutelength
shaftdiameter
angle
numflutes
stickout
coating
metric
notes
machine
material
plungerate
feedrate
rpm
depth
cutpower
finishallowance
3dstepover
3dfeedrate
3drpm
601
whiteside
6210
601 Fly Cutter 6201
end
1
0
0.25
0
2
3
0.25
0
10
80
16000
0.01
1
35
80
16000
602
Sugelary
X002JUT7TF
602 Fly Cutter
end
1
0
0.25
0
2
3
0.25
0
10
100
16000
0.01
1
35
100
16000
If you are using the McFly that is likely already programmed in the factory tool database.
To modify a custom tool already created:
Open CC
Go to About Menu
Click on the Open Data Directory
Navigate to the Carbide Create Directory
Navigate to the Tools Directory
If you have already created a custom tool you can click on that custom database and it should open in a spreadsheet. You can edit and then save as a .csv file. Do not let the spreadsheet save in its native format because CC cannot read that only a .csv file.
You can create a custom tool but there is much more you can add by using the above procedure.
I set my Max Depth to 0.0001" so it outputs 0.000". If you reopen / edit the toolpath you have to type it in again, as CC rounds it off to 0, and will give you an error.
Then I check my surface in several places, and set Z to 0.005" at the lowest spot. Now I know my table is at Z0, and when I set zero on a workpiece the readout tells me exactly how thick it is. 3/4" stock is rarely exactly 0.750".
