I agree std behavior for a rectangle would be corner to corner. We already have the option to hold CTRL and draw corner to corner. I’d suggest we make that the default, and use CTRL to draw from center.
Metric/Inch should be open & available at all times, rather than buried in the setup menu
Notes should be a menu option so you can access it from everywhere
Now that I think of it, the “Setup” bar could be present in all tabs??
We have a “Snap to Grid” toggle. A “Snap to node” toggle would be cool. Hotkeys for both would be even better.
Rotation in the 3D views is odd. I think rotation should be relative to the view, not the model space.
Lighting is also, I think relative to model space. I think it should also be fixed in the view.
Rotation center point could also be in the center of the view. If I zoom in & rotate the model rotates out of the window.??
For geometry creation, OK, APPLY, CANCEL buttons would be nice. OK creates the object & dismisses the dialog, Apply creates the object & leaves the dialog to create another, Cancel just dismisses the dialog without creating anything.
Geometry selection for toolpaths is wonky. Even after 2 yrs I still select a toolpath, then realize I forgot to select geometry first. If vectors are selected it should use them, otherwise let us assign them in the toolpath dialog.
When working on or viewing someone else’s file, if they have used custom tools we can’t see the tool definition. An option to “Add tool to library” option, or at least a properties / info button for the tool would be good.
The same happens with fonts. Although fonts are not CC proprietary so at best we could expect the font name & any other information relevant to acquiring that font.
Organization in the toolpath list is good (groups). “Save toolpaths”, and maybe Simulation as well should be based on the currently selected group or toolpath, rather than everything that’s enabled.
Modeling changes the 3D texture back to cherry. It’s a bit of a pain to keep going back to toolpath simulation to change it back to the material you want.
Library, posts & tools should not be embedded in the software. They should all be in the data directories.
CM should be the same for tools, that way tool prompts could use custom tool data, and the user could share/copy tool database from CC to CM
CM should also have exposed macros, so the toolchange, measure tool, set zero, end of program macros can be customized.
That’s all I can think of now. I’m sure others will add more.
