I attempted to start of simple project of cutting four small pieces. I completed the program in Carbide Create Build 764. After initializing the machine, using my BitZero, I started the project and the program started the cut about 2 inches to left of the clamped material. I can find a way to remove this offset. I rewrote the project and went through the proper initiation, and BitZero probe. Upon starting the program an offset right and forward appeared. I am using Carbide Motion Build 622. Any suggestions as to how remove what appears to be an offset.
Post your C2D file, so we can see how things are set up there.
3 Piece Extention Blocks.c2d (96 KB)
Thanks for looking at the file. David
