When creating a new curved line that is not a closed vector you are unable to edit the nodes in “node edit” works fine for polyline but not curved. And also works for “curved when you don’t actually curve the line?” Or if you close the vector.
Upload the file you have this difficulty w/
Don’t need help with a file, it’s literally exactly how it is in the video. And repeatable on the last beta as well as new build.
New Curved line and then node edit, you can’t delete a node or add one. You can only cut the curved line in node edit. Very repeatable. Windows 11 Pro
Launch Carbide Create build 815:
Create a Curve:
Done
Draw an additional line which touches an end:
Done
Select both:
Join Vectors
Yes
go into Node Edit mode:
right-click to Insert Node:
delete the added node:
Done
It’s 815 for sure. I’ll wait for a patch and revert the software. Not adding an extra line just to edit every single curved line I add.
Works just fine on V5, stopped functioning on V6
