Unable to connect pink lines in my simple pocket project
Will / Tod1
I just tried Tod1’s 4 circle’s with center offset of 1 inch and then boolean which worked just fine (more than one way to skin a C#* … Low and be hold and I’ll be snookered…! it worked I was TOTALLY amazed minimum of key strokes. now I try and move it to G code and to the machine
Big Thank you to both of you 4 your time I let U know how it works out.
Ken
Tod1 gets the prize for efficiency but here is yet another way:
  • With the size tool, extend the four lines one at a time so they all intersect.
  • Trim vectors to remove the line segments beyond the intersections.
  • Join vectors to combine the remaining lines into a diamond (all black lines now).
  • Select diamond and use the fillet tool to fillet 1 inch, replace original vectors.
The circles are extraneous.
Yep.! I am sure this would work also sounds a little more complex but I’ll have to try it one of these days
Tks
Ken
