Highly Frustrated after spending (Big bucks $$$$ 4 me anyway) for Carbide Cut Pro and MANY DAYS trying to get 4 circles in a triangle to form a pocket 8" wide and 11" high and its 4 pink lines to connect the 4 circles on the out side edges and then to use boolean to trim the inside of the circle off using boolean.
to form a pocket tray type thing. I am doing this project just to get use 2 CC pro but so far nun, nota, nothing and about ready to give up.! OPPS now in the drawing one of the pink lines has turned “black”
I did nothing to change anything.??
The pink line which has turned black has been self-closed — you’ll want to go into Node Edit mode and cut it so as to open it again — when you do so, do that at both ends and you will get two objects, one of which can be deleted.
Please post the file here or send it in to projects@carbide3d.com and we will gladly walk through this with you.
Will
Thanks for the quick reply.!
I think ? I have tried that about a gazillion times… But not the right combo of key strokes… I’ll try it again and if I still can’t get it I post the file.
Thanks
Ken
Will;
this is one I just started from scratch have not tried to use boolean or node edit on this one yet. hope I have the upload right.?
Thanks
Ken 4cBoolean1.c2d (44 KB)
Will:
OH yea in all the hacking I have seen the Boolean selection box empty with no options to choose through out all my try’s to get this to work that info. may or may not be of help or a bug in CC Pro.?
For a boolean option to appear, you must have at least 2 closed vectors selected. If one of two vectors is open, there will be no options. With other combinations, only options that will affect the object are available.
For your part, I would zoom way in at the end of each line.
Select the line, and Edit Nodes. Drag the line past the tangent point so you have a good idea where it is
Drag the end point to that position, as close as you can get it. Repeat this for all 8 end points.
Now connect the ends to form a closed shape, and Join the vectors.
Thank you, Ken and Tod1d for the lesson on how to do this. In the past I have played successfully and unsuccessfully with this. Now I can see what is required. I downloaded your file and worked it to success.
For this particular arrangement, since it’s all even & symmetrical & the circles are the same size, you could create a single polyline from the 4 circle centers
Will
here are 3 screen shots for the boolean option
still have not got it to leave just the out side radius MORE PLAYING is needed. and then I need to remember all these steps. I just saw the 2nd way from tod1d may give that a try.
Tks
Ken
After many many hours of trying 2 edit on this file I think I have messed it up totally… Anyway here is the file if you zoom in where the radius were the end cuts are visible ragged. I don’t know what else to do it is beyond my knowledge as how to fix it (frustrated again).? It just should not be this hard.!
