Unable to use my touch probe with the CM575 build
Had to switch to a new computer, when I did, I downloaded the new CM575 for windows 11, I was using a mac previously. When I tried to set my zeros for a work piece the probe setting only allowed for individual movements to the touch block, I saw no button to set the probe for XYZ at the same time. Meaning I had to manually set the zero for Z, then move the machine manually so the bit was on the correct side and low enough to check the X axis then manually hit the X probe to start the movement. Then I had to do the same for the Y axis. When all was said and done, I ran the program, and the cut was jacked up the machine cut twice the depth it was supposed to and in the wrong location on the work piece. So, my question, is there a setting I screwed up to not allow me to use the probe like it was intended.
When you switch to a new computer, you have to resend your machine configuration.
Also you have to tell CM which version, 1 or 2, you have for it to operate properly. After you set which version you dont have to change it and it will use the proper version you have.
I just went through this too. You can’t go back to your old computer either, without re-sending the configuration to the machine. Stick with one computer…
