I don’t understand why CC is creating a tool change when I have two consecutive operations with a 90 Vbit. The next tool has consecutive operations with an 1/8 endmill and no tool change is generated.
How can I control these changes? I’ve included the CC file, as well as, the NC generated.
Carbide Create only supports using V endmills for V carving toolpaths — it expects a square or ball-nosed endmill to be used for a contour or pocket toolpath.
Presumably this is a bug caused by that assumption.
The comment before each tool has a different diameter 0.001 & 0.5. I’m wondering if the definitions being different cause a tool change even when the tool number is the same.
