Updating Grbl 0.9 on CarbideMotion v2.4d controller
I have owned a Shapeoko 3xxl since 2018. Haven’t used it in quite a while and now there is an urgent need to reenergize it. My older Carbide Motion software that used to run the machine is not available any longer, and it seems that the newer ones don’t run with GRBL 0.9. Would any one have any advice whether to upgrade GRBL to 1.1 or revert to an older CM software version.
We have older versions at:
https://carbide3d.com/downloads
so you could download and run CM3 as the machine is, but might need:
https://www.microsoft.com/en-us/download/details.aspx?id=40784
If you have homing switches, then updating should work, see:
If you dont want to upgrade I have an archive of most CC and CM for the last 6 years. Let me know what version you want and I will put it on google drive.
It would be better to upgrade but…
