Thanks, lowering the switch to 3mm above metal did the trick indeed.
And here’s my cover, bottom is closed plastic, I’ll ask support, but if anyone has something useful to add with regard to this old setup, but now without the fan I like to hear it… My gut feeling says the cooling bracket is the whole x axis aluminum extrusion, so it should be fine if it’s fine for the new enclosed setup.
