Upgrading to Shapeoko Pro XXL or go for a completely different machine?
Thanks a lot for sharing all those thoughts!
I’ve done what I can to optimize the tool change part and I’ve also worked quite a bit on optimizing for speed, but it still takes about 1.5 hours to do the whole bottom of the jewelry box. I don’t think I can get it down more than that with my current setup.
Which spindle are you using? Was it a difficult upgrade to do and does it make the workflow more difficult? From what I understand the spindles are both quieter and cooler. Is that true?
I was afraid that a machine with an ATT would be a lot more expensive. I could live without as long as I can do long runs on the machine. For example, on the Shapeoko Pro XXL I would be able to fit 4 of the jewelry box bottoms on (maybe even 6), but that would give a runtime of 6 hours. Do you think that would be a possibility with an industrial vacuum and a spindle instead of a router? What would be the limiting factor in that scenario?
