I need to know how I can upload an image into the library for an inlay project I want to do?
Under the Library menu there is import from a url. I tried that and it went to my local harddrive where I have a lot of svg and bitmap images. The pictures never showed up only folders. The thing is if you already have the image it does not need to be in the library just import an svg or open a bitmap to trace. Perhaps someone will answer why you cannot upload into the library.
Help | About | Open Data Directory
go into the Carbide Create/library sub-directory and create a directory to organize .svg files into, and then place them there:
So you manually move your images ? What is the purpose of the menu to upload images. Is that just not working.
Its an Import option, not an Upload option. It imports images to the workspace.
