Hey everyone! I have read some old posts and found that some people are using this touch probe with custom macros and/or a different gcode sender. Is anyone currently using this successfully? I wanted to use a BitZero v2 which I bought but due to the use of SMW fixture plates and mod vices, conductivity probing isn’t going to workout for me since the fixture plate is mounted directly to the aluminum extrusion and all of that is grounded to the machine. The bitzero works fine as long as I’m probing a corner as it’s designed to do, but if I want to flip the plate upside down and probe a previously machined hole from the 1st OP it won’t work. Would love to see who is using this or something similar these days!
