Hi foolks,
I’m new here and I have an issue with carbide create. If I design an object and select inside of Toolpath a slef created library with a end mill, wich is in Millimeter, and select this, I got the information in left side of Toolpaths with 0.0 %. After a while, windows 10 crashed without an error.
If I look after that into Sytem Management Console under adminstrative event I can see, that ucrtbase.dll is the reason for the crash. Tried on different PCs. Is there a solution for this?
If I select a predefined toll from the library everthing is fine.
