V Bit Carving - Why are the corners not square?
Hello friends,
Just completed another project. This time I used a 60 degree V bit for the lettering.http://a.co/d/998uDO5
Here it is:
IMG_20181226_135233
I noticed that I all the corners are always rounded. This appeared in my tests as well. I believe it is because the V bit I am using has a 1 mm tip. Does anyone know how to correct this?I have also tried varying the zero height but it doesn’t correct the issue, It just makes the text more narrow.
Thanks for the input!
Possibilities:
  • uneven stock
  • Z-axis zero set too low
  • V bit angle incorrect / doesn’t match what was used in CAM
If this appearance matches the preview and you’re using Carbide Create the problem is that the geometry is wider than the V endmill can cut — inset the geometry twice, cut the inner and outer as a V carve, then the middle as a pocket to the depth of the V Carve.
I have (cough cough) had unsquare corners several times, and 100% of the time (for me) it was always caused by having the Z set too deep.
There’s a reason why I set the Z too deep, but that that something we need to get into here…
Remember, wood is seldom flat/parallel, and where you set the Z is not where all the machining in taking place…meaning the thickness if the wood varies…
@panf Try raising your zero to 1mm (exact would be 0.866mm) .above your surface if you’re flat is 1mm in diameter and you’re using a 60 degree bit.
Link to calculator in this post:
Hi all,
I think this bit isn’t appropriate for V carving.
At one angle the bit comes to a point. Turn the bit 90 degrees and it goes to 1 mm. When I raise the Z height to compensate the text gets narrow because not enough material is being milled at the widest point.
I will the 302 bit from carbide3d to compare and reply with the results.
Shipping times may vary. Lol
Thanks all
I remember buying this exact same bit, getting poor results, then getting Carbide3d’s Vbit, and suddenly getting nice Vcarved jobs :slight_smile:
Yours is also chipped. I use one of these from time to time, and it’s “ok” at some things (chamfers), awful at others (vcarve is not it’s strong suit). A solid carbide one works better, and they’re pretty easy to get (amazon has the whiteside 1541 for ~$20)
