Hi I have a 1/4” v- bit with a 15.24mm diameter 3 flute 90degree can anyone help with the settings to add the tool?
WillAdams
(William Adams (Carbide 3D))
2
The concepts for this are covered in:
but since 316 and before we’ve switched from entering taper angle (half what V endmills are defined as) to nominal angle (the 90 degree you cited).
system
(system)
Closed
3
