I added a 90 degree v mill to my tool library but it previews the cut as a flat endmill. You can see in my picture the angle, diameter, and flute length are correct but every time I try to preview the gcode it looks flat. is this normal?
Normal, No, but it’s a known bug in carbide create.
ok so I can stop pulling my hair out and give it a try thanks. Any recommended feeds for a 90 v milling poplar? I’ll google it I guess
I run 70 to 80 IPM regularly.
