So I am still undecided on CC v7, seems to be too many bugs or maybe it is just me, but have few questions that came about when switched over.
Did all the Shapeoko’s get summed up into one when going to select a tool and choose machine type?
Also the tool database settings seem to have changed. But one issue I have noticed is 3D ball nose shows 5% step over for .125 bit, but clearly the step over is not 5%. It shows default to be .62 which is 50% not 5%.
So did you all modify the tool database default settings and feed rates? Yes I know I can change them but not the point. And ideas?
I am running v7 with 556 CM Shapeoko 4 XXL Pro
