VCarve Inlay Settings Steeper Angles
Hello All -
I’ve done quite a few VCarve inlays with great success, mostly following the video posted by Winston and using a 60 degree vee bit. I have a project coming up that’s more detailed and wanted to try using a steeper bit to get a deeper inlay on the more detailed areas. Unfortunately the steeper the bit I tried the looser the inlay was. Here are the parameter and bits I tried with:
Female = .25" depth, 60 degree vee bit (302)
Male = .23" plug depth, .04 top gap 60 degree vee bit (302)
Eanosic (E252) 30 degree
Whiteside (SC50) 22 degree - SC50 - Whiteside Machine Company
Amana Tool (45783) 18 degree - 45783 Solid Carbide Carving Liner 18 Deg x 1/4 Dia x 5/8 x 1/4 Inch Shank x 1-Flute
I was surprised that just changing the angle caused such a difference in the inlay fit. At least in my head it seems as long as the same bit is used for both male/female parts the inlay should fit the same regardless of angle.
What am I missing here?
What is the best parameter to experiment changing in order to get a well fit inlay?
Ideally I wouldn’t have to offset one of the vectors to get a snug fit.
All suggestions welcome!
First inspect the tips of the V-bits. If they are not perfectly pointed, they will remove extra stock from both sides, causing a looser fit.
Next create a small test part where the inlay overlaps the edge of the workpiece so you can see and measure the fit. Reduce the plug depth for a tighter fit Add the same amount to the top gap to keep the same total depth of cut.
Fit, measure, adjust.
Note the corrections for each tool.
Thanks!
Never thought of overlapping the inlays over the edge. Much more efficient way to trial and error.
