VCarve Pro Machine Acceleration
When using VCarve Pro the time estimate window allows you to enter settings for your machine speed x,y&z. I’m not exactly sure how you would determine those settings does anyone have any info on this for a SO5.1 with a 65mm VFD?
@Pchuk , if you go to the MDI window in Carbide Motion, open a log, and then enter/send $$ it will read out all the machine settings, and the accelerations will be in there at $120, $121 and $122 for the X, Y and Z axes. It’s a big readout so you’ll likely need to scroll back a bit in the log.
Thank you I’ll check it out.
