I have an XXL, HDZ and 2.2 watt spindle, BitSetter, touch probe and working with VCarve. Until I get comfortable with the bitsetter I still export individual files for each tool and use the bitsetter macros for CNCjs that @neilferreri has provided until I get comfortable with the new multi tool workflow using the bit setter.
The issue I have is that the spindle isn’t getting up to full speed before the cutting starts, there is no “pause for spindle to get up to speed” that I can find. Is there a different post processor I should be using for VCarve?
Like this: (just add the “G4 P5.0” at the end for adding a 5 second spindle RPM ramp up time)
+ Commands output at the start of the file
begin HEADER
"G17"
"G21"
"G90"
"G0[ZH]"
"M0"
"G0[XH][YH][S]M3"
"G4 P5.0"
Yeah so the G4 P5.0 must not be in the right place in the post-processor file, because it shows up before S20000M3 (which is the command starting the spindle…).
Check your post, and/or send it we’ll check together
