This is my first time working with basswood - I typically vCarve hardwoods or mdf. Made 2 attempts so far (back and front) and it comes out very fuzzy. The carving is too small to pick or sand out the fuzzy parts. I plan on picking up a second piece and making another attempt. Any suggestions? What feeds/speeds and dewalt rpm settings would be appropriate?
I’d start with what the wiki has. Though it looks like the information was based on the dremel/shapeoko 2.
I’d maybe go with 4 on the dewalt? Not sure what your speeds/feeds were previously.
I have had luck with fuzzier woods by doing similar to what will I will run the toolpath, leaving the part place put a coat of poly/shellac/varnish (I use poly) let it dry then run the path again.
