I know fusion 360 has adaptive clearing and a lot of people are using it. I’ve played with it a bit but am not comfortable at this point to be running my first aluminum project.
I use V-carve pro for everything and am very comfortable with it.
Is any one else milling aluminum use v-carve tool paths? What results have you been getting? Thanks Ray
I’ve done aluminum and brass on Nomad, using toolpaths from Meshcam and Vectric. As long as the feeds and speeds are good for the machine/tool/material there is no problem. Start slow and speed up from there was my approach, and other than a few “learning moments” it worked out fine.
