Running CC Pro Build 813
Just imported an SVG that is a small part of a project. Since I wasn’t sure how the import might be treated by CC, I took the precaution of grouping all the vectors for the two (identical items). Then I clicked both of them, clicked on Align Vectors, and then the right one of the three choices. Nothing happened, repeatedly. Horizontal centering worked, but not the vertical.
Just now when I repeated the process, to be sure I was writing everything correctly. Vertical
centering worked immediately. No clue.
So I deleted what I had imported and grouped, and tried the vertical center again. Nothing.
Attaching the C2D file and the SVG file.
Enclosure - End Caps.c2d (52 KB)
