VFD spindle controller flashing but not running
I have an S XXL PRO. Due to some unseen circumstance i was never able to use or connect my VFD spindle i purchased in march of 24. (I was homeless) Now i have my maching up and purring and grabbed the spindle box to get it set up. I plugged everything in correctly. When i give it a command, the gantry moves but the spindles will not turn on. Ive tried to do some self diagnostics but no luck. The controller box is flashing numbers. Not sure what to do. Any help would be appreciated!!!
I am a new user also, so I have very limited experience, but did you push the button toward the bottom front of the VFD? It may be in the spindle off position.
You may need to go thru your machine setup sequence and ensure it’s configured for the spindle vs a router. You can search this forum or go thru the setup videos Carbide 3D provides.
If you need to re-run the Setup Wizard, see:
https://my.carbide3d.com/docs/shapeoko-setup/
