Last night, I noticed a “cycling” sound while cutting, but didn’t think too much of it. This morning, it got much worse…turned off the VFD/Shapeoko/CarbideCreate/CarbideMotion, re-powered-up and still have the same behavior.
This is a finishing pass with a 1/4" spiral, so barely 0.02" and you can hear the speed rapidly changing. Additionally, this should be at 18000 RPM, but barely gets to 12000, frequently dropping to 5000 and back. Note that you can hear the cycling even when the bit isn’t engaged
