First I want to say I LOVE my new VFD and Spindle from Shapepko. I’ve had it for a couple weeks now and finally got the time to actually use it today.
I am posting this here as I think what I’m about to ask resides in CM.
My first use today went pretty good. I did have what I will call a couple hiccups tho and would like to know what I can do to correct this.
The issue I had was that on a couple of bit changes the VFD did not shutdown the spindle ( most of the bit changes the VFD turned the RPM off correctly), it did everything else correctly. I had to manually press the button on the VFD to shut it off so I could change the bit, use bitsetter and then turn it back on.
Is there something I should look for to correct this ?
I do love the VFD and spindle tho, quite as can be!! Well worth the money.
