VFD Spindle will not plug into Shapeoko 5 Pro
I finally received my VFD Spindle. I have a Shapeoko 5 Pro and do not know where it plugs into it. There is a spot that says spindle but the plug in does not fit. Does anyone know if there is another place to put it?
Which spindle did you order?
I ordered the VFD spindle kit.
There should be a small pigtail connector to make up this connection included with your Shapeoko 5 Pro — if you didn’t get it, let us know at support@carbide3d.com
Found it. Thank you.
How do I install the VFD spindle on Carbide Motion 6? I tried to follow the Youtube video and it seems they use a different version.
This is now done in the setup wizard:
https://my.carbide3d.com/docs/shapeoko-setup/
Do I have to set up the entire machine all over again?
